Posted by Dennis K (WA) on May 23, 2013 at 13:51:06 from (24.21.78.195):
I can't believe this system is whipping me but it is.
Farmall H, 6V positive ground, cutout relay and four position light switch.
Problem is no charge at low setting and cutout points do not close in low setting.
Normal output in hi, 10-15amps warm and as high as 18amp when cold. The third brush is moved up as far as it will go, 3 bar spacing on the commutator and against a stop on the end plate.
Checked grounds with ohm meter;
batt gr to dash screw or switch .1 -.2
batt gr to gen/cutout .4 -.6
F post on gen to switch .1 -.2
This has been this way since restored a few years ago and finally decided to deal with it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
