Posted by Zachary Hoyt on May 27, 2013 at 14:38:59 from (184.12.74.99):
In Reply to: IH 31oader posted by Bill Bowen on May 27, 2013 at 14:26:22:
They are pretty simple, I have one off an H and now on a 300. The axle clamps bolt around the axles, the front arm bolt to the frame rails and the other doodad that is separate is for alignment and bolts to the front casting. The two pipes on the loader go through the two pipes on this part to keep the loader from swinging from side to side. The doodad has spacers that are used on an H and not on an M, I would save them for future reference or sell them someone probably can use them. Zach
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
