Re: IH 31oader
Posted by RustyFarmall on May 27, 2013 at 14:59:36 from (216.248.71.226):
In Reply to: Re: IH 31oader posted by Zachary Hoyt on May 27, 2013 at 14:38:59:
The doodads go on the outside if you are mounting it on an M. If mounting on an H, the doodads go on the inside. That way you don"t need different lengths of bolts. Pretty ingenious really how the IH engineers figured that one out.
