Posted by Matt Tieken on May 28, 2013 at 11:04:01 from (66.64.242.10):
OK, the 706 starts great, runs great and so far, bush hogs great. There is a little valve noise, so I got a set of feeler gauges to adjust the valves.
I am not sure I am hearing things, but after I work it for a while, and it is good and warmed up, After I pull it around to the barn and put it in neutral, it sort of sounds like a rod is knocking.
If I put the engine under any load, like putting it in gear and moving, the knock goes away until I push in the clutch. Does this sound right?
If it is a rod, it isn't the end of the world, but I would like to catch it before it lets loose. If it isn't a rod, I am trying to think of what it might be.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
