300 cut off raking
Posted by VA Gasman on May 29, 2013 at 19:19:20 from (75.197.60.99):
This new to me 300 has only 4 hours on it since I put in new plugs, points, wires rotor. Has Ran perfect. But today I put it to work raking. first time it has run this long with out stopping. After 45 minutes in 90 degree temp it starts missing. I stop look at points setting and they look good. Starts right up and then 10 minutes later starts missing again and cuts clear off. won't start.
Come back 30 minutes later starts right up. I parked it. It has been converted to 12v and the coil is so hot you can't touch it. Is this the culprit or do I look at points and condensor?
Randy
