Re: 300 cut off raking
Posted by El Toro on May 30, 2013 at 03:47:46 from (108.3.218.181):
In Reply to: 300 cut off raking posted by VA Gasman on May 29, 2013 at 19:19:20:
Your NAPA store should have this 12 volt coil that doesn't require a ballast resistor. Hal
IC14SB
