CUB STARTER WORKS ON BENCH BUT NOT ON THE TRACTOR
Posted by lekander883 on May 31, 2013 at 04:00:09 from (184.158.12.147):
6 VOLT SYSTEM.. STARTER SPINS OF THE BENCH. BUT WHEN I PUT IT ON THE TRACTOR WITH GOOD JUMPER CABLES RIGHT FROM THE BATTERY IT HITS THE FLYWHEEL AND STOPS. I CAN TURN THE FLYWHEEL BY HAND WITH THE FAN BLADE... I BOUGHT A NEW BATTERY AND EVEN TRICKLE CHARGED IT OVER NIGHT.. WHATS WRONG..?
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
