Re: CUB STARTER WORKS ON BENCH BUT NOT ON THE TRACTOR
Posted by Denny ('60 Lo-Boy) on May 31, 2013 at 05:16:58 from (76.1.35.110):
In Reply to: CUB STARTER WORKS ON BENCH BUT NOT ON THE TRACTOR posted by lekander883 on May 31, 2013 at 04:00:09:
Clean ALL battery cable connections down to bare shiny metal. Clean face of starter and the tractor to bare metal. You likely don't have a good ground.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
