Re: inspecting a used hydraulic pump for an H
Posted by riverbend on June 01, 2013 at 06:15:08 from (74.46.177.49):
In Reply to: Re: inspecting a used hydraulic pump for an H posted by Janicholson on May 31, 2013 at 16:54:40:
The 350 uses hytran, so using 40 wt in the H is not a good option.
If the bushings in a used pump are good and there is no wear in the housing, it should be a workable unit ? Springs and balls wouldn't be a problem.
Greg
