Re: inspecting a used hydraulic pump for an H
Posted by Janicholson on June 01, 2013 at 06:45:12 from (74.60.94.18):
In Reply to: Re: inspecting a used hydraulic pump for an H posted by riverbend on June 01, 2013 at 06:15:08:
That is correct. on the 350 tick, Ticks like that are often a chipped trans tooth. The TA has little in it that can tick. The Drive gears for the PTO can ne one location toward the front. Look at the caseih.com parts diagram for the trans. Jim
