Posted by Jim Becker on June 02, 2013 at 09:14:24 from (173.57.153.141):
In Reply to: 200 fluids posted by clint s on June 02, 2013 at 08:47:11:
You have correctly ID'ed all the plugs. You can ignore the filler plug on the PTO as it runs in the same oil as the transmission. The plug is there more so you can see and adjust the bevel gears than it is to add oil. I think IH recommended dumping some oil in there when a PTO was newly installed and was dry. Doesn't really matter as plenty of oil will be there within a minute of starting the engine.
As has already been stated, the hydraulic system doesn't use oil from the transmisson. So gear oil is adequate. On the other hand, Hytran is a "better" oil. So most of the arguments for using newer/better oil can be made. I'm not going into that argument here. You can dig through the archives and find more than you want to read on that subject.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
