Re: H Lift-all pressure relief cap blows off
Posted by pete 23 on June 03, 2013 at 10:28:07 from (74.44.101.209):
In Reply to: H Lift-all pressure relief cap blows off posted by riverbend on June 03, 2013 at 06:55:43:
You mean the button over the top of relief valve right. It is to trip the lever when relief valve opens. They get bent over the years as they should not move enough to allow the button (cap) to come out of place. I have bent many back into shape as the lever is malleable case. Easy does it. Also, the pin gets bent allowing excessive clearance for cap to come out of place.
