Re: H Lift-all pressure relief cap blows off
Posted by riverbend on June 03, 2013 at 18:31:25 from (74.37.52.196):
In Reply to: Re: H Lift-all pressure relief cap blows off posted by pete 23 on June 03, 2013 at 10:28:07:
That's the one. The lever looks straight, but there is enough space to reinstall the cap by just lifting the lever and compressing the spring. Are the higher pressure (700 psi) caps longer ? This one is about an inch long.
Greg
