Re: More diagnostic info on the 460D
Posted by pete 23 on June 03, 2013 at 20:53:31 from (74.44.101.209):
In Reply to: More diagnostic info on the 460D posted by picassomcp on June 03, 2013 at 20:14:35:
It labored, made noise. Make sure valves are still timed. In other words, when on top dead center number one cyl, the number six cyl valves should both be tight. Intake just starting to open and exhaust just finishing closing. I have seen them engines keep running with a broken crankshaft, but if it depends on where it breaks to determine if it will remain in time or not. You could have a sheared key on injection pump drive but I doubt if you would hear any noise. With starter removed you can rotate engine back and forth to tell if all components are moving in sync.
