Re: Adding a starter solenoid?
Posted by Yankee Ron on June 04, 2013 at 11:01:54 from (70.88.46.10):
In Reply to: Re: Adding a starter solenoid? posted by pete 23 on June 04, 2013 at 10:12:47:
Pete - I think you're correct - the foot pedal pushes at an angle and keeps messing the switch up. The tractor itself is 12 volts (battery and generator w/ mag) but the starter is 6 volts, so I think a 12 volt solenoid should do ok. It's been working well like this for years and was set up that way when I got it so I never saw a reason to spend the $$ to change it.
