2504 / 504 Valve arm block will this fit?
Posted by ja1724 on June 05, 2013 at 10:00:32 from (96.57.208.235):
I have discovered numerous issues with my rear hydraulic 3pt/draft/lift control assembly. I have what I believe to be a 1967 IH 2504. I found this one from a 1964 IH 504. Mine has the two levers (position & draft) This one seems to only have the position control lever (unless it's just that the draft one is missing). Could anyone please tell me if this will fit & work on my tractor. Thanks much.
Here it is:
third party image
