Re: 2504 / 504 Valve arm block will this fit?
Posted by farmallboy15 on June 05, 2013 at 10:48:16 from (184.20.163.36):
In Reply to: 2504 / 504 Valve arm block will this fit? posted by ja1724 on June 05, 2013 at 10:00:32:
If it looks the same as your 2504 I would venture to guess they are the same; since the 504 and 2504 are based on the same chassis. For the draft control it looks like only the lever the missing. The splined shaft is still there meaning you should be able to slide yours off and slide it on there. I'm not sure how intensive it is to switch out that part as I've only had the cover off on my 504...
