Posted by Bill in IL on June 06, 2013 at 06:05:58 from (132.3.49.80):
Having some issues with the governor on my 560. I have wide open throttle and low idle any speed in between is really hard to get. It also will not hold or recover rpm when pulling a load.
I removed the governor last night and can see nothing obviously wrong with it. Weights are loose and the thrust bearing looks good.
How much spring resistance is the leaf spring inside suppose to give? It doesn't give much just enough to act as a buffer at full travel. I assume the spring external to the governor does most of the work.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
