Posted by pete 23 on June 06, 2013 at 10:46:04 from (74.32.230.205):
In Reply to: 560 governor posted by Bill in IL on June 06, 2013 at 06:05:58:
The 560 in notorious for poor linkages all the way from throttle to gov and they had a lousy gov in the first place. I would unhook throttle linkage and operate the gov manually to see if problem is gov or linkage. Many governors have been changed over the years so hard to tell what you have on there. Higher speed engines use smaller weights, same spring and internals as a lower speed engine. I worked on a 656 that someone had put on a 706 gov and there was little control of speeds. It over revved and throttle linkage did not match with movement of throttle.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
