Re: Farmall 656 Problems
Posted by ejr-Ia. on June 06, 2013 at 11:22:13 from (208.79.0.168):
In Reply to: Farmall 656 Problems posted by Darren Mann on June 06, 2013 at 08:20:55:
Maybe not a thick enough gasket on the housing and the gears are meshed to tight.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
