Farmall 656 Problems
Posted by Darren Mann on June 06, 2013 at 08:20:55 from (69.66.201.160):
I recently had a local mechanic repair my hydraulic pump and clutch. Now I still have a growling noise coming from the hydraulic pump as if it is low on fluid. I also have no brake on the left side. The break locks the wheel or won't engage it makes a noise like a slipping gear when you press the pedal on that side. Is it possible the mechanic could have done something to mess the brake up on the left side when he split the tractor? What could be causing the noise from the hydraulic pump? He even replaced the drive shaft to the pump and the gear on the pump. I'd like to know whether I should call him and ask him to look at it again or find a new mechanic.
