Posted by caterpillar guy on June 06, 2013 at 19:31:50 from (24.231.176.175):
In Reply to: Farmall 656 Problems posted by Darren Mann on June 06, 2013 at 08:20:55:
Ask for the old parts. Then count the teeth to see if they are the same gears. Then the gasket as already said could be different thickness. Like if he is one of those silicone mechanics for gaskets. That would make it to tight. If the old gear was worn enough to need replaced the one it meshes with might be worn causing the noise. I would guess he replaced the drive in the front of the transmission going into the back of the pressure plate rather than the pump gear. If so then he should have changed the seal and bearing in there too. Could have missed one of the o-rings between the pump and housing or it fell out during installation. Lots of food for thought.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
