Re: Remove 140 belt pully unit?
Posted by Haas on June 07, 2013 at 18:04:44 from (50.142.111.41):
In Reply to: Remove 140 belt pully unit? posted by Red Whiskers on June 07, 2013 at 05:00:28:
You can remove it but you will need to find a cover plate. A flat plate won't work because the shaft extends beyond the mounting surface. You might as well just leave the assembly in place. However, when you remove the pulley that Watson there for your Woods mower, you must install a sleeve with retainer bolt over the splined shaft that the pulley was on. The seal on that shaft runs on a bushing, not directly on the shaft. The pulley or the sleeve must be on there to keep the bushing in place. If you loose that bushing, you will have a serious transmission oil leak.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
