Re: 6 volt regulator and a 8 volt battery ?
Posted by Janicholson on June 10, 2013 at 17:03:06 from (74.60.94.18):
In Reply to: 6 volt regulator and a 8 volt battery ? posted by Irving on June 10, 2013 at 15:30:37:
With it running, and the gen Arm wire connected to the VR arm terminal, ground the field terminal on the gen with a jumper(connected to the regulator or not, it does not matter) if it now charges some you know the issue is in the Voltage regulator. *.5 volts or so may be all it will deliver, but it should charge with a Voltage regulator that is good.
Adjusting the relay with the smaller terminals a little tighter, and making sure the contacts are clean, might work. (I won,t make noise about it being 8 volt) Jim
