6 volt regulator and a 8 volt battery ?
Posted by Irving on June 10, 2013 at 15:30:37 from (208.103.158.101):
How do I set the volt. regulator to charge a 8 volt battery? I took off the top of the reg.cover and fooled with the two adjustment screws as I watched the volt charge gauge. Still less than half(Discharge)on the gauge. Now what?
