Re: 6 volt regulator and a 8 volt battery ?
Posted by mkirsch on June 11, 2013 at 05:19:42 from (64.80.110.75):
In Reply to: 6 volt regulator and a 8 volt battery ? posted by Irving on June 10, 2013 at 15:30:37:
Either your regulator is no good, or your generator is no good, or you have a grounding problem.
Did the generator charge the 6V battery before?
