Posted by Haas on June 15, 2013 at 12:02:11 from (96.38.10.42):
In Reply to: Fuel line on a Cub posted by charlie M on June 15, 2013 at 11:24:03:
Yes, there is supposed to be a screen in the sediment bowl. Sounds like you need to flush out the tank. First I would try removing the sediment bowl from the tank. Then get some 3/8 pipe fittings, some hose and rig up a drain to a container. Then flush out the tank with some diesel fuel. That's safer than using gasoline. Get the tank and lines as clean as you can. Go to NAPA and get a no. 3032 fuel filter and install that in the line between the sediment bowl and the carb. After you get the carb cleaned and a kit in it, I bet you will be good To go.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
Latest Ad:
[More Ads]
