Re: Super W6 Ring Replacement
Posted by sflem849 on June 15, 2013 at 20:08:35 from (69.197.84.39):
In Reply to: Super W6 Ring Replacement posted by David MacBride on June 15, 2013 at 19:36:19:
I doubt you will get the pistons out without using a ridge reamer. If you use a ridge reamer you might as well use a hone.
