To get the alternator to work now take the short wire that is on the alternator output post and plug it into the #2 terminal on the alternator.
Since you are now running 12 volts to the coil you can use that as a feed for the #1 terminal. You just need to take the resistor that you are no longer using for the coil and install it between the battery side of the coil and the #1 terminal on the alternator.
The resistor you have may not have enough resistor for this alternator application. If the engine wants to stay running after you shut off the switch you will need a resistor with a higher resistance or use a diode instead.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
Latest Ad:
[More Ads]
