International 684 Hydraulics
Posted by Stuiart on June 22, 2013 at 12:28:03 from (79.69.97.39):
Hi guys, I read a thread on here about faulty steering and brakes on an IH 684. I had the same issue. I followed the steps (removed 1 1/8" plug on bottom of MCV) all that came out was the bung and spring and couldn't see or feel anything else. I put a tray under the valve and started the tractor and almost instantly got a jet of oil out and so stopped the tractor. There was nothing came out except oil, and so, confused I put the spring and bung back in and, steering works fine!! Only trouble now is that the loader and 3 point linkage is jumpy, slow and appears weak. Is it possible this is due to air in the system with taking the valve apart, and if so how do I bleed the system. Or is there another reason, did something come out that I didn't see? There was very little oil lost during the blow through so I don't suspect low oil level. Any help greatly received... Thanks in advance.
