Posted by riverbend on June 22, 2013 at 14:24:25 from (70.101.157.63):
The H was running fine, put it in the shed. Next day, it won't start. It is flooded. Clean the carb. No luck. Put a kit w/ needle and seat in the carb. No go. Check the float in hot water. Nothing. Install carb top on tractor. Slightest pressure on float shuts off fuel. I can move the carb top 1/8" in any direction before the floats contacts the carb body. Install assembled carb and fuel drips out of weep hole.
It acts like the float level changed overnight. What am I missing ?
Thanks
Greg
ps Went through the ignition system several times since most carb problems are ignition related... It will throw a blue spark about 1/2". That seems okay.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
