Re: H carb flooding - stumped
Posted by wayne in mn on June 22, 2013 at 16:32:48 from (71.8.147.138):
In Reply to: H carb flooding - stumped posted by riverbend on June 22, 2013 at 14:24:25:
Remove carb drain plug & empty the carb by turning off the tank shutoff. Turn on the tank valve and allow the gas to flush any small particles past the needle & seat. Shut off the tank valve & install the drain plug. Turn on the tank valve & check for leaks. Sometimes a small hammer tapping on the carb bowl will help.
Could also try rubbing-cleaning the needle tip and make sure the needle is not rubbing on the side of the seat.
