Re: IH 404 - Fluid from gear shift
Posted by Harold Hubbard on June 24, 2013 at 08:27:15 from (205.209.16.24):
In Reply to: IH 404 - Fluid from gear shift posted by dravery1 on June 24, 2013 at 07:58:13:
Mine did the same thing. Water contamination makes
it foam up and overflow where pure oil might not.
You also may have enough water in there to seriously
over fill it. I think the water got in the same way
that mess is coming out. Some sort of boot over the
shift lever might help that. As far as sealing goes,
mine never gave a problem after I dealt with the
water and overfilling.
