Re: Farmall Cultivision A won't run but about a minute??
Posted by LarryE44 on June 24, 2013 at 10:52:20 from (69.35.184.59):
In Reply to: Farmall Cultivision A won't run but about a minute?? posted by LarryE44 on June 24, 2013 at 10:25:03:
I cleaned the fuel tank and cleaned the sediment bowl. The tank has fuel in it. The valve is open on the sediment bowl going to the carb. Otherwise, there probably would not be fuel in the carb bowl as I mention in my OP. I took the carb completely apart and put it in the soak. When it stops running, I open the valve on the bottom of the carb and there is fuel running out.
This is the first time I've heard that Berryman's is a poor choice for a carb cleaner. What would you recommend?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
