Re: Farmall Cultivision A won't run but about a minute??
Posted by RustyFarmall on June 24, 2013 at 12:11:13 from (216.248.71.226):
In Reply to: Re: Farmall Cultivision A won't run but about a minute?? posted by LarryE44 on June 24, 2013 at 10:52:20:
When you open the valve on the bottom of the carb, how much fuel runs out? There SHOULD be a steady stream, about the size of a pencil.
GUNK brand carb cleaner is about as good as it gets, but thanks to the EPA, even the Gunk is not nearly as good as it used to be. The old time carb cleaner was powerful enough that you DID NOT get it on your skin. It would take the skin off your fingers if you did.
That Berryman's stuff is so weak that I can fully immerse my hands in it with NO ill effects.
No matter what you use, you need to finish the cleaning process with a can of aerosol carb and choke cleaner. Stick that nozzle right into the various ports and holes and spray until it comes out somewhere else.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
