Posted by MRF-Engines on June 24, 2013 at 17:15:35 from (75.89.152.22):
I have been working on rebuilding the engine on a 1942 Farmall A. I ended up having the replace the crank pulley, but the replacement (used from another 1942 A) one is loose on the crankshaft. I put the old one back on to check and it is tight. Is it possible to shim the replacement pulley or do I need to find another one? Thank you.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
