Loose is not acceptable. They are usually an interference fit of great difficulty to remove (I have seen 20 ton applied before it gave up a millimeter. If it was a locational fit that was just movable on the shaft, I would drill and tap for a set screw, then grind a flat on the crank, or drill a divot in the crank to accept the crown of a crown point set screw. If loose, a different pulley is best. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
