Re: Farmall 656 D Oil Pressure Sending Unit
Posted by TractormanNC on June 25, 2013 at 04:49:12 from (108.72.58.200):
In Reply to: Farmall 656 D Oil Pressure Sending Unit posted by Tip 'n NJ on June 25, 2013 at 04:33:07:
1. left side of block right in front of the breather tube about 1 inch above the frame rail.
2. can't help you on this. I make my own wireing harnesses.
3. cup plugs are correct. you want the heater as low in the block as possible. heat will rise to the cylinder head. good luck on getting one of those threaded plugs out.
