Re: Need a little clarification on setting valves
Posted by El Toro on June 25, 2013 at 17:24:19 from (108.3.218.181):
In Reply to: Need a little clarification on setting valves posted by Paul Shuler on June 25, 2013 at 16:50:36:
Bring No1 piston to TDC on the compression stroke, then set valves 1-2-3-5 counting from the fan end of the engine. Rotate the engine one full revolution and set valves 4-6-7-8. Set the clearance at .017" cold. Hal
