Re: Very stiff steering on C
Posted by Harold Hubbard on November 23, 2000 at 05:30:42 from (209.198.117.25):
In Reply to: Very stiff steering on C posted by Paul Shuler on November 22, 2000 at 21:00:04:
You didn't say whether it's a WFE or Narrow. If it's a WFE Jack it up and disconnect the steering arm at the center. Now see if the spindles will turn easily. If they don't check for looseness, or binding, also look for cracks wher the spindle tube is welded to the axle. If this is all good or if it's a NFE, With it still jacked up see if the steering has freed up. If not pull out the worm shaft and check the bearings and see if the shaft itself is straight. If this is not the problem then it almost has to be the bearings in the front bolster. In a WFE they seldom give trouble unless they have gone without oil or gotten moistur into them. Ina narrow front, they have been carrying the whole weght of the front end for almost fifty years and may be due for a vacation. If you really need easier steering after everything is right, find an old truck steering wheel of bigger diameter, and fit it to the shaft. Don't overdo on the diameter, you still need room for your knees, and if the wheel has very much dish to it, the steering shaft will have to be shortened. I have been through this movie several times, one C two Super C's, and an M. If all else fails, I suppose you could put a Char-Lynn stering unit on it. I have never seen one on a C and I suspect it would be overkill.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
