Re: Very stiff steering on C
Posted by Haas on November 23, 2000 at 06:39:46 from (129.37.117.87):
In Reply to: Very stiff steering on C posted by Paul Shuler on November 22, 2000 at 21:00:04:
Something wrong! I have a 1950 C and it steers very easy. This in spite of the fact that I have a problem with the front bolster that holds the steering gear which is makeing a lot of play in eht steering. I'll ditto the suggestion of TomH to jack it up and see if it turns easier with no weight on the wheels. Then you should be able to isolate the problem.
Post A Followup
: Re: Re: Very stiff steering on C
