Re: F-20 flywheel installation update
Posted by Phil Tibbetts on July 01, 2013 at 08:23:33 from (208.93.14.38):
In Reply to: Re: F-20 flywheel installation update posted by EM Iowa on July 01, 2013 at 08:02:50:
Do you think it will get smaller? I've never seen a key I couldn't get out. Try drilling some small holes along the key and you should able work it out with a hammer and chisel.
