574 hydraulic leak
Posted by Bill Allis on July 02, 2013 at 14:32:32 from (69.207.42.247):
My 574 leaks hydraulic fluid when hot. I crawl under it and cannot find a fitting leaking or anything dripping, but the underside of the tractor is oil covered. After the tractor cools down the leaking seems to stop. There is no puddle of oil after it sits for a week or two.
Is there a breather that could be plugged? It is not overflowing at the dip stick hole. I simply cannot find a leak.
Any ideas?
Bill
