Re: 574 hydraulic leak
Posted by JimB2 on July 02, 2013 at 16:24:14 from (99.241.76.141):
In Reply to: 574 hydraulic leak posted by Bill Allis on July 02, 2013 at 14:32:32:
Hi Bill,
Is it leaking by the clutch inspection plate on the bottom of the torque tube?
If so could be a seal on the PTO, transmission input shaft.
Most common leaking problem is PS pump and PB cylinders and lines.
JimB
