Re: IH 684 Hydraulic Fluid Change Parking Band
Posted by Cyrush on July 02, 2013 at 14:33:00 from (81.156.47.240):
In Reply to: Re: IH 684 Hydraulic Fluid Change Parking Band posted by StuartR on July 02, 2013 at 13:39:48:
Hi stuart!!
The hydraulic top cover does not need the cab to be removed to do the handbrake band, and in theory the oil can be left in, but!! As the crap from the band is probably blocking the suction strainer for the transfer pump, re the intermittent hyds you commented on earlier?? You need to give it a good clean out. To do this you need the pto side cover and MCV off!!
