Found this with Google-COMPRESSION RING INSTALLATION
Ring installation instructions are placed in every set of piston rings Hastings Manufacturing Company produces. These instructions should be read each time before the piston rings are installed on the pistons. Listed below are the general rules for the installation of various types of compression rings.
Rings having a "pip" mark or dot on the side of the ring must always be installed with the "pip" mark or dot towards the top of the piston.
Rings with a bevel on the inside diameter but no "pip" mark or dot must be installed with the bevel towards the top of the piston.
Rings with a groove in the outside diameter and no "pip" mark or dot must be installed with the groove toward the bottom of the piston.
* Rings having no dots, bevels, or grooves can be installed either way.
It is a good idea after installing all rings on the pistons to recheck each ring on each piston for correct installation
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
