Re: 826 German diesel hard to start
Posted by The tractor vet on July 04, 2013 at 17:23:03 from (75.19.127.29):
In Reply to: 826 German diesel hard to start posted by Nathon on July 04, 2013 at 09:37:56:
Hard starting problems can be several things . (1) your pump and injectors may need rebuilt . (2) the valves may need to be readjusted (MAY) (3) it may need a valve job as if the valves are setting down in the head to far then this will reduce cranking compression. (4) your sleeves and pistons maybe plum slap wore out and you are low on cranking pressure . You have no idea when or IF it was ever overhauled . So you maybe looking a a total rebuild and if you have to go that route then install the updated pistons and make sure the machine shop knows how to get the valves as there proper height. and do the fuel system at the same time . If it has been started with EITHER SHE GO OR EITHER SHE BLOW then i am betting on the total rebuild .
