Posted by Nathon on July 04, 2013 at 09:37:56 from (216.227.55.31):
I recently acquired an IH 826 German diesel with a Bosch fuel pump. It has about 10,000 hours on it and it also has the gold paint. Anyway it will not start, in any weather, without ether. I have checked the pump timing per some posts here on YT and it appears correct at 16d btc. Once running it seems to run pretty well. I have little knowledge about these motors so I thought I would ask you guys what sort of checks can I perform before I begin spending big cash on it. What should the compression be on this model? Thanks in advance!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
