Posted by D7fever on July 05, 2013 at 17:06:01 from (72.79.239.29):
In Reply to: Farmall H backfires posted by Shop teacher 94 on July 05, 2013 at 15:01:17:
had that same problem, turned out to be champion plugs. It could also be condenser,or coil. possibly broken point set. If you have a magneto, it could be something different. Distributor is located on the right side of the engine, just below 2 and 3 sparkplugs. Magneto ignition is located in the same place. It also could be a broken distributor cap , one time had a stick wind its way up and break it. Good luck
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
