Farmall H backfires
Posted by Shop teacher 94 on July 05, 2013 at 15:01:17 from (173.85.9.34):
Got a question for you all. I just bought a 43 Farmall H, it ran decent until the other day when it just died...I was pushing some half sunk RR ties out of the ground. I got it started again, but it Ran real Rough...then started backfiring, compete with a bit of flame coming out of the stack. What would cause this?
I am new to the Farmall, so if you have an idea, you may need to put it in real detail, so i can understand them.
I did replace the plugs...gapped at .025. # of the 4 plugs were fouled up. looking like it ran a bit rich.
From looking through the forum, it looks like the next logical place to go is the points...but I have no idea what I am looking for or where they are located.
Thanks in advance.
Dusty
